02-04-2024, 09:40 |
The correct score bet is considered the best and most lucrative type of bet in football. However, to win big, you need to have information about the odds as well as some betting tips. Don't miss the article below with Wintips to understand more and pocket some effective betting tips vip free
How football score betting works
Football score betting, also known as "Correct Score", requires players to accurately predict the final score of the match in order to win the bet. This type of bet is divided into many forms, including: exact full-time score, exact half-time or second-half score, and self-selected exact score.
Each score will have its own specific payout odds, publicly listed by the bookmakers before each match. These odds usually fluctuate depending on market factors and match developments. Scores with lower payout odds are more likely to occur, and vice versa.
Therefore, to easily win in this type of bet, players need to analyze the basic factors of each match to determine the appropriate score.
Some common types of correct score bets
As mentioned above, correct score betting includes various forms of betting, including: Full-time score, half-time or second-half score, and self-selected score.
Full-time score bet
In this form of betting, players wager on the score of the official 90-minute match, including injury time. The full-time score bet will be settled immediately after the referee blows the final whistle of the official match time.
Half-time/Second-half score
Players will bet on the exact score of the first half or second half. The betting time is counted from the beginning of the match until the end of the first half or second half, including injury time. To understand better, let's follow the example below.
A match has a score of 2-1 in the first half and ends with a final score of 3-4. In a half-time score bet like this, you need to understand the following:
The first-half score is 2-1.
The second-half score is 1-3.
Self-selected score
This is a less common type of bet, so many may not fully understand this type of bet. With this type of bet, players will bet on both the first half and the full-time score according to their preferences. This means you bet on how you think the match will unfold.
View more articles : betting tips group on telegram
Guide to participating in score betting at online bookmakers
Below, we will guide you on how to participate in score betting on football matches online. Specifically as follows:
Step 1: Access the bookmaker
First, players should find and access a reputable bookmaker. After successfully accessing it, navigate to the login section to log in to your betting account. Once logged in successfully, players select the Sports section on the menu bar of the website.
Step 2: Choose the score
After entering the betting area, you should explore, select the tournament, view the odds table, and choose your favorite score.
Step 3: Enter the bet amount
After selecting the match and the preferred score, enter the bet amount and click on the betting box to complete the betting process. The minimum amount to place a bet at online bookmakers is 10,000 VND per bet slip.
Standard score betting experience without adjustments
Score betting is a type of bet with relatively low odds. Many matches may have outcomes that are not within the predicted possibilities provided by the bookmakers. Therefore, betting on score results is often for entertainment and testing luck rather than being a favored betting type among gamblers.
Depending on each bookmaker, the odds for score betting may vary. Therefore, you should consider and choose the bookmaker that offers higher odds.
According to the experience of long-time gamblers, to increase the winning rate when betting on score results, you need to choose multiple scores in the same match with equal stakes. Minimum of 3-4 bets in one match.
However, players need to have a good capital source and know how to allocate capital properly. Because of the difficult nature of this type of bet, without proper capital allocation, it's easy to lose all your money.
Additionally, players can also pocket some scores for selection through analysis such as: Performance, goal-scoring probability, historical match statistics, etc.
Above are some information football tips site about score betting as well as some experiences when participating in online betting. Hopefully, it will help you have more useful information when choosing betting options.
Full-time score bet
Self-selected score
